Unable to install AmigaSport 3.0
Started by BrianM, 15 June 2004, 19:36:50
BrianM
Hello,
I am running Win XP Pro on a PIII 533 with a Voodoo 3 3000 AGP card. Whenever I attempt to install AmigaSport 3.0 (the tools portion), I receive the following error:
Error 1904. Module C:\WINDOWS\system\3dfxCmn.dll failed to register: HResult -2147221164 Contact your support personnel.
If I choose the "ignore" option, I get the same message for several other .dll files.
Note that this occurs even after I completely remove all old drivers and reboot my system before the installation.
Any suggestions would be greatly appreciated.
Brian McNeilly
Did you try "Repair" in the 3dfx tools ?
- first install, ignore all the errors
- install again, and choose "Repair" in the 3dfx tools
BrianM
Well, the repair option didn't work, but when I completely uninstalled the AmigaSport I noticed that the registry was updated. A second attempt to install the tools after that worked OK.
Brian
