Voodoo 3000 & Counter Strike
Started by DopeJam, 25 July 2003, 12:12:28
DopeJam
Diablo works better when I enable v-sync :) Sometimes after restart it works good but sometime(after restart) it doesnt runs fine, I dont now whats the problem with my f****ng computer
perhaps a problem with the vsync because running with vsync enabled limits your max. fps to your monitor refresh rate...
even i don't know why Diablo seems to work better (visual problem ?)
__________________________________________________
Voodoo Woman
DopeJam
its faster with vsync on, I dont know why
faster ?
what is your refresh rate ?
Voodoo Woman
DopeJam
u mean monitor? 85 on 800X600
KillerOPS
look for 3dhq voodoo3 drivers. I'm using them on windows 98, with a little overclocking (200Mhz, big k6-2 500 cooler on the v3 3000) and it's 10fps over any drivers i've tested yet. It goes around 50 fps on a k6-2 550 with 128mb on a via mvp3. I believe your problem might be comming from the cpu too, because those cpus don't have good floatingpoint unit
3dfx gone, but never forgotten...
