Voodoo 3000 & Counter Strike
Started by DopeJam, 25 July 2003, 12:12:28
DopeJam
yo I have dx9b now, still the same with CS :(
DopeJam
my motherboard is m787cl+ v3.0
ArchAngelCD
QuoteOriginally posted by DopeJam
If I have this correct you are using a VIA C3 CPU.
I'm guessing there is a problem with the C3 CPU or the SiS630E chipset.
Do you have the newest BIOS update?
http://www.pcchips.com.tw/BIOS.html
Do you have the newest IDE drivers. Version 4.42 are on the site.
http://www.pcchips.com.tw/ide.html#winxp
Other than that I can't think of anything else. [?]
Asus P4P800 i865PE | Intel 2.8 GHz P4C | 512 Mb Kingston PC3200 Dual channel DDR SRAM | 80 Gb Western Digital SE HD | Plextor 12/10/32A CD-RW | Win2000 SP3 | ATI Radeon 9500 Pro | SoundMAX 5.1 Digital Audio|
____________________________
DopeJam
em Im going to instal win2000 do you think that would resolve my problems???
what is the best voodoo 3000 pci driver for win2000?? what else do I need?? (wickedGL....)
and why not Win98SE, probably the best OS for the game...
anyway, you will find drivers here :
http://www.falconfly.de/voodoo3.htm
well, with CS, i will begin first with "old" drivers
3dfx Voodoo3 V1.07.00 (Win98Xx)
3dfx Voodoo3 V1.03.00 (Win2k)
DopeJam
have now win2k sp4. With the standard win2k driver CS crashs I will try now 3dfx Voodoo3 V1.03.00 (Win2k).
DopeJam
shiii have the same problem with 3dfx Voodoo3 V1.03.00 and amigamerlin too I dont think this is a grafic card problem. Whole comp freezes after 10 seconds I tried with dx7 and dx8.1
Friday
PEOPLE!
WIN XP is not good for playing games! Win 98 is still the best choice.
I have celeron 433, 128 megs of ram, 3 GB HD, voodoo3 3000 (oc to 190 Mhz) win 98, dx 9.0a. In CS fps goes between 70 in large areas to 230 in houses. Use WickedGl, it helps!
DopeJam
and driver??? I have now win98se with wickedgl fps is better but in fights is still 10fps heeeellppp I cantttt anymoreeee.
I tried oficial 1.07.00 beta and amigamerlin 2.5 but it doesnt heeelpp. I have dx8.1
ArchAngelCD
QuoteOriginally posted by ArchAngelCD
Did you try this[?][?][?][?][?]
DopeJam
yes I have the newest bios, drivers etc.
Amigamerlin 2.9 and 3dhq beta 10 - doesnt increase FPS, too
**** man.
Friday
Did you try to flash your voodoo card? If not, do it. It's very simple. I'm using 2.15.12 bios (modified by DRAMinit). If you are going to flash it, download the recovery tool too (in case something goes wrong, and read the instructions!!!)
finally how is setup your gfx card ?
DopeJam
Im finished, no chance even diablo 2 doesnt work fine. I dont know I tryed everything
hum, a new install with Win98SE would be interesting
and what's happened with Diablo 2 ?
ps : is v-sync. enabled in the 3dfx tools ?
__________________________________________________
Voodoo Woman
