Can Voodoo2 work without pass-trough cable?
Started by HamaZ, 03 March 2006, 11:02:37
HamaZ
I intent to acquire a CRT monitor with dual VGA inputs, so I thought to connect one input to my Matrox Millennium II, and another to the Voodoo 2. But in this setup the pass-trough cable from Millennium II to the Voodoo 2 is surplus. So, will V2 work without it?
That can work.
But perhaps it is a little difficult to use on a daily basis.
The best would be that the monitor lets you switch between the two inputs when needeed.
HamaZ
Of course. The monitor has a dedicated button for instant input switching. Thank you for confirmation.
