Installed driver for t&l, now game wont start up
Started by hungbig, 18 February 2004, 18:40:34
hungbig
I am having problems With No one lives forever 2, It gave me a system error of no T&L in video card and no 8.1 installed on sytem. I currently have 9.0 dx on my system and installed a driver that has geometry assist, but when I get to the very start of the game it takes me back to win98 start screen, what gives. How can I remeide this problem?
If this game needs T&L, you need 3DAnalyzer
If you are under XP, try this patch
https://www.3dfxzone.it/dir/news/3dfx/nolf2_3dfx.htm
But i guess that you're under Win9x since you're using a driver having the geometry assist. This function in the driver is not sufficiant. Download 3dAnalyzer, the last version 2.31 and try to run the game with it.
https://www.3dfxzone.it/dir/tools/3d_analyze/index.htm
Post again if you need help ;)
Geometry assist is good ONLY for some games that are based on DirectX-7.
NOLF 2 is a DirectX-8 game, so disable geometry assist and try 3D-Analyze.
My_Spleen
rashoman2003
