Profile link (edit your...) doesn't work in Opera
Started by ggab, 19 May 2004, 08:11:05
the link:
http://www.3dfxzone.it/enboard/pop_profile.asp?mode=goEdit
loads only partial, in Avatar Selection stop!, and all the following page doesn't load anymore...
so when i need to change some settings, i must use IExplorer :-(
so, with Internet Explorer everything is OK.
But i think the forum has same bugs (only in Profile?) with Opera 7.1x and newer... (still in 7.5 beta1).
Tnx for report: this is a forum engine issue.
At this moment i suggest using I.E. to browse board with all features.
Hovewer, a future upgrade to most portable application is probable.
i tested with Opera v7.54 and... WORKS:D :D :D
maybe, the updated brower or because when u fixed the:
Quotewe have solved forum problems so now it's again possible open topic and/or reply to these.
thanks ;)
