IMPORTANT question!!
Started by Knuckles, 28 October 2003, 05:38:33
Knuckles
Ok, here, it seems that the Via chipset on mobo with AMD CPU HATES VSA-100 Voodoos, I talked to some people having same troubles as me with other brand but still AMD & Via.
I want to know, what Mobo are you using w/chipset, CPU & Video card (VSA-100 ones)and if it's working  ok or if it constantly  freeze. If its the mobo, I wil change for a nVidia chipset one.
thanks!!!!
Do you only want to know about motherboards with VIA chipsets for AMD CPU's?
Knuckles
I want to know for everyone using a V5/V4 on his system.
