ATI, Nvidia, Intel, AMD
Started by youkaizero, 25 April 2005, 01:13:36
youkaizero
I want to find out from everyone.
Do you perfer ATI, or Nvidia?
Do you perfer Intel, or AMD?
Post why as well.
My choice?
Ati, Why?Nvidia cards are mostly just updates of older cards( Same with the 9600 XT with ATI, But oh well ).Bigger selection of cards, and different types of graphic cards.
Amd, Why? Amds are cheaper, and can run as fast as a Pent 4 even though the front bus isn't as high.And plus AMDs are good with overclocking.
AMD Athlon 64 3000+
1 gb ddr
Western Digital 80 gig
ATI Radeon x800
ATi vs. nVidia:
Well, duh! ATi offcourse! nVidia is evil!
Intel vs. AMD:
Difficult. AMD's CPU's perform better at same speeds than Intel's CPU's but Intel has the Pentium-M which performs almost as good as AMD's CPU's but requires much less power.
My current CPU is an Intel Pentium 4 2,26GHz and my next CPU will probably be a Pentium M. Unless AMD's Turion promises to be a good counterpart.
youkaizero
The Pentium M is horrible. I'm warning you, even though it's low voltage, it's low performance as well.Can't do to many things at once.
AMD Athlon 64 3000+
1 gb ddr
ATI Radeon x800
