Can not capture screenshot!!!!!!!!!!!!
Started by Teff, 05 July 2005, 04:04:22
QuoteOriginally posted by roflkopp
-------------------------for Win98/Me--------------
REGEDIT4
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Display\0000\FEATURES\Glide]
"CategoryNumberSlots"="4"
"CategorySlot2"="Screen Shot"
"CategorySlot3"="Screen Shot Key"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Display\0000\Glide]
"FX_SNAPSHOT"="1"
"FX_GLIDE_SCREENSHOT_KEY"="111"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Display\0000\Glide\Screen Shot]
"Control"="Combo"
"Default"="0"
"List"="Disable,Enable"
"Previous Value"="1"
"Tweak Map"="0,1"
"Tweak Value"="FX_SNAPSHOT"
"Value"="1"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Display\0000\Glide\Screen Shot Key]
"Control"="Combo"
"Default"="0"
"List"="Disable,Num-Lock,Key-Pad /,Key-Pad *,Key-Pad -,F12"
"Previous Value"="2"
"Tweak Map"="*,144,111,106,109,123"
"Tweak Value"="FX_GLIDE_SCREENSHOT_KEY"
"Value"="2"
Why I can find :
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Display\0000\FEATURES\Glide]????????[|)]
Eveybody, bad news again.........[|)]
Black screen again!!!!!!!!!!!![xx(]
Anybody can help me?????????
I think I can only use
HypersnapDX 5 to capture screenshots......[|)]
It is the tool which I can capture screenshot.........[B)]
Only this one......[:(]
Everybody,
any other suggestions?????[|)]
Another thing that is the quality of the screenshots
captured by HypersnapDX are bad......[xx(]
How can I improve their quality??????[:(]
REGEDIT4
"FX_SNAPSHOT"="1"
"Control"="Combo"
"Default"="0"
"Tweak Map"="0,1"
"Value"="1"
"Control"="Combo"
"Default"="0"
"Value"="2"
And I use your method to capture screenshots(by MesaFX),
the screenshots are too blur(I think),[|)]
how to improve the qulity ????????
Can you tell me?????[|)]
