Best V5 5500 Driver for OLD GAMES
Started by dopoh, 03 March 2005, 20:59:26
DrCR
I'm using 1.09 Beta10 on WinME to play Independence War : Deluxe. DriverHeaven.net link <here>
DrCR
_________
Defder
Official 3Dfx drivers is the best
Caravel
#17
1.04.01 -beta should run quake on a Voodoo5 without problems.  You won't need to tweak it at all, it will run fluidly.  This is the kind of software that these cards were designed for.  Good choice. :)
-Edit: And Voodoofiles is disorganised and no longer has a forum.  The 3dfx.com site appears to be down as well...  other forums are very quiet also... evidence of the state of decay...  The end is nigh.
