Eliteforce2 on Voodoo3
Started by Atalagon, 26 June 2003, 16:28:42
Atalagon
I see there many graphical glitches and it seems to be to run under directx... :(
Which driver and related settings have you used?
Atalagon
I solved problem already, using wickedgl as opengl32.dll in EF directory
Atalagon
But i would like to know, when there will be a new amigamerlin for XP :)
Testing step is in progress: i want give you a good and stable release so you must wait a right time.
Don't warry, therefore, for this ;)
