3DMark 2001SE Build 330 Scores
Started by NitroX infinity, 23 October 2003, 21:14:49
Mikulaish
Hi! My 3dmark 2001 score with my V3 3000 AGP v1.0 no tv out is 2495 (1024x768x16bit). System specs:ECS k7vta mobo, TBred 2200+ @ 140Mhz Fsb, 512Mb ram Kingmax CL2.5, V3 3000 @ 199Mhz. Regards. Alpar
Sega Dreamcast
In my travels, I have noted that the Voodoo architecture scales based more on FSB speed than CPU speed. The faster your FSB, the more powerful your Voodoo card is going to be. That is the only explaination why a dual Athlon MP setup scores worse than a single Athlon XP setup. One is 133Mhz(DDR), the other is 166Mhz(DDR).
gerzonj
Abit kx7-333 (via kt-333)
Amd (barton)2500+(11x185mhz)
512mb(400mhz)Samsung
3dfx Voodoo 3 3000 agp 166mhz default
3dmark   99:7100
3dmark 2000:3400
3dmark 2001:2500
                :D [8D]
Ralf
Damn
my score is 1280 [:p]
i dont know why is so small [xx(]
I use
Pentium3 550 @ 825 mhz (5,5 x 150)
+ 256 mb Winbonds 2 2 2 5 -
Voodoo 5500 @ 205 mhz (defualt clock = lower score)
and AmigaMerlin 3.R11
any sugestions ?
powered by
3dfx Voodoo5500 Rev.A1 3000 With DVI out based on MT-55
Intel C2d @ 3,7ghz + P35
Raff3DC
Yep – a new CPU. Every Voodoo is very CPU dependant due to the lack of HW T&L, mainly when testing such a T&L-optimized Voodoo-hater like the 3DMark series. ;)
Greetings from Germany,
Raff
Ralf
then its normal score on P3 -825mhz and V55k [?] (1280)
btw
i think in games/3dmarks CPU Amd is better than Intels Core [:I]
powered by
Dan350z
My score is 2955 for my Voodoo5 5500
CPU:  Mobile AMD 2400@ 2088
Mobo: A7V333
MEM: DDR333 1024mb
VID: 3DFX Voodoo5 5500 AGP, Amigamerlin 3.1-R11
OS: XP Professional
Scores:2955
Default 3DMark settings (1024x768@32bit): 2955
http://service.futuremark.com/compare?2k1=8965017
I am now trying to figure out a way to hit 3000.
Dan350z
forefront
see my computer system on singature and i get 1243
Computer number 1 Voodoo 5 5500 64mb agp, 1.5gb ddr ram, AMD Athlon 1700+(1800+ - 1900+}
Computer number 2 voodoo3 3000 16mt pci<3 PIII 1000mhz 256mt sdram 133mhz dvd-driver. Win2000.
alex.turovsky
#38
An amazing 2010 score on a PIII machine ! ! !
after a year from the previous reply, LOL, I got a record !
Project Voodoo test machine: http://www.iopanel.net/forum/thread12920.html
Pentium III Tualatin 1130mhz overclocked to 1400 mhz !
512RAM (Intel 815E chipset limit)
Asus TUSL2-C
3DFX VOODOO 5 5500 1.18B BIOS 166mhz Overclocked to 190mhz with modded heatsinks Zalman 2x VF900-Cu LED  heatsinks !
"He who controls the past commands the future. He who commands the future conquers the past". Kane,  Red Alert 1 1996
- Journalist of the Israeli PC Plus magazine.
- Personnel and Hardware forum admin in EDS Israel unit.
alex.turovsky
i wonder if the bios i use 118.b is better than any other for overclocking? or the best drivers? I cant go past 190 mh"z . . . and I have ****load of cooling [:(]
DerBiber
System:
AMD Athlon XP 2700+ (Tbred) @ 2167
Epox 8k5a2+
1gb corsair ddr333
Voodoo5 5500 (1.18 @ 166)
win98se (using the lastest inof. service pack)
1.04.00 3dfx ref. driver set
(geo. assi. turned off)
3dmark2000: 5932
3dmark2001: 3013
(may win98se gives a little boost)
guess using a voodoo56k upto 8k should be possible with some tweaks ;)
and by the way intel machines aren't that much worse at all using a voodoo5 5500. my tualatin 1,4 is pretty close to the athlon xp in all game-benches I did (Q3A 110(AMD) ~ 101 (Intel). only the 3dmark benches are showing a difference between 300~500 points.
pierrickuk
QuoteOriginally posted by DerBiber
System:
Epox 8k5a2+
1gb corsair ddr333
3dmark2000: 5932
3dmark2001: 3013
I know it's a long time but if you have the hardware, could you run some benchmark to compare with my results in that thread (http://www.3dfxzone.it/enboard/topic.asp?TOPIC_ID=16745)?
Do you know if that sempron 2600 s754 is such a bad cpu for voodoo gpu in general?  I'll try to get my hands on the best or second best cpu that ms-7032 can handle if that could help.
marksoft15
#43
QuoteOriginally posted by alex.turovsky
Asus TUSL2-C
Greetings to all members of 3dfxzone.it
I am new to the forums, I've read if for quite a while but never posted before.
I want to express my gratitude to people like Daniel Borca, Koolsmoky and many other developers whom have made possible that we can use our 3dfx hardware even today, and to all the members who have helped so much to keep 3dfx alive, I hope I can to collaborate to go on.
I saw alex.turovsky benchmarks, and I realized that he has very similar hardware to mine, so I wanted to share my benchmarks with you.
Pentium III-S 512KB L2 Tualatin 1266mhz overclocked to 1600 mhz !
512RAM (Intel 815E-B chipset limit)
Shuttle Spacewalker AE25 non RAID
3DFX VOODOO 5 5500 stock BIOS 166mhz not Overclocked and running on retail heatsinks
I ran few different benchmarks with different FSB frequencies, I attach some files.
It puzzles me that I got 2107 3DMarks, but I am running on stock heatsinks and my voodoo5 5500 agp at 166MHZ. Nevertheless I run on XP and it is quite tweaked, so maybe it helps.
Greetings to all and if anyone wants to contact me I provide my contact data on my profile
Marksoft
IT Solutions specialist and 3dfx enthusiast.
I own:
Diamond Monster 3dfx voodoo1
3dfx Voodoo3 3000 AGP & PCI cards
3dfx Voodoo5 5500 AGP
166 MHZ of system BUS
150MHZ of system BUS
133MHZ of system BUS
I attach 3dmark2001SE files if you are interested in details
sites.google.com/site/marksoft15/166mhzbus.zip?attredirects=0&d=1
sites.google.com/site/marksoft15/150mhzbus.zip?attredirects=0&d=1
sites.google.com/site/marksoft15/133mhzbus.zip?attredirects=0&d=1
Gaz
here's my 3Dmark 2001 SE score on voodoo 5 5500 PCI :
test system :
windows XP 32bit
2GB DDR 400 ram
250GB HDD
AMD Athlon 64 3500+ @ 2.21Ghz
Standard V5500
3DFX.. the way it was meant to be played. ;) lol
3D mark 2001: 2671
3dfx voodoo5 5500 PCI
DFi LAN Party NF4 sli-D
AMD Athlon 64 3500+ @2.21GHz
2GB DDR400 ram
250 GB maxtor HDD
