Windows Update site
Started by justin, 03 October 2011, 16:31:34
justin
Since 2 or 3 weeks I'm unable to acess the Windows update site with Windows 98. Anyone else having this problem? Microsoft won't help only says Win98 is not supported which I already knew.
Yep, same here.
I tried it last Friday and it seems IE6 is locked in an infinite loop when trying to reach the Windows Update.
justin
Thanks for responding.
It looks like it's finally over with the 98 updates site. I doubt they'll fix it. They could've put a message there instead of this, asses. Anyway I guess we'll have to use the 98se 3rd party service pack since it has some of the Windows updates in it.
