slot 1 fsb 200
Started by ms-dos, 28 May 2009, 23:18:27
i have a older pc and it has a slot 1 but the fsb is 200 i never herd of this i only seen a fsb of 133 is this right or i got a fast pc:D slot 1 for a processor like a pentiun one two
Likely your bios's working badly.
the bios are not bad it is a $500 motherboard and i cam overclok a pentium 3 333mhz to 500mhz:D by just uping the fsb
What are you talking about ?
There is no Pentium3 with 333 Mhz.
And 200 Mhz FSB on a Slot 1 system is impossible.
About your great 500$ mainboard : What is the exact name of it ?
i can not post pics do to them being to big[V] so if you wan't to see thim you will need to give me your e-mail or the size of file upload will need to be chang
try to use this link:
http://imageshack.us/
for posting fotos.
You can resize also the picture !:)
QuoteOriginally posted by ms-dos
here is sum info on my pc
http://www.active-hardware.com/english/reviews/mainboard/be62.htm
so did anyone look at this link
