Speed guide for Amigamerlin 2.5 SE optimal setting
Started by Glide, 18 July 2003, 14:59:43
This driver setup is to get a balanced level of performance and quality
OS: Windows XP - 3dfx Voodoo3 2000/3000/3500 cards
SYSTEM
-AGP command fifo: 2x or autodetect
-Highest quality video: enabled
-Refresh optimization: disabled
-Via chipset: performance
DIRECT3D
-3d filter: quality high
-Alpha blending: sharper
-Auto mip mapping: enabled
-D3D guardband clipping: enabled
-Anti aliasing: fast performance if you like run games at high  resolution, else 2X enabled (until 1024x768 resolution) or 4X (lower resolution suggested).
-Edge aliasing: enabled
-Level of detail bias: 0
-Maximum buffered frames: 1 pending buffer
-Mip mapping dithering: disabled
-Rendering color depth: software controlled
-Speed setting fastest v-sync: disabled
-Trilinear filter: disabled
-Triple buffer: enabled
-Z buffer optimizzation: enabled
OPENGL/GLIDE
-16 bit depth precision: fast
-32 bit depth precision: fast
-3d filter quality: high
-Anisotropic filter: 4 tap
-Anti aliasing: as for D3D games
-Edge aliasing : enabled
-Force 16 bit texture: disabled
-Force 3d now! instruction: on
-Force mmx instruction: on
-Force voodoo rush emulation: disabled
-Glide 32bpp rendering: software controlled
-Glide guardband clipping. enabled
-Glide refresh rate (monitor dependent)
-Glide triple buffer: enabled
-Hidden surface removal: disabled (enabling yuo could see visual artifacts)
-Legacy texture compression: enabled
-Limit texture memory: disabled (enable for compatibility with old
games)
-OpenGL guardband clipping: enabled
-OpenGL culling: enabled
-Speed Setting fastest v-sync: disabled
Of course you'll be find not all settings in your driver control panel because some features are typical of Voodoo4/5 hardware or VIA based motherboard only: just reply what is on in your 3dfx Tools.
