Lost pod
Started by saint_germain, 23 May 2009, 20:00:50
saint_germain
Hi, last month, I´ve buyed a voodoo 3500 tv, but without the cable pod. searching on the web, i can´t find the cable pinout, someone has the pìnout?
I Knows something of electronic, so i can solder the cables, but i dont know where!
Plese, help me.
Thanks in advance!
saint_germain
Nobody knows something?
Please, help me.
I think I have them somewhere,I'll paste them here when I find them.
saint_germain
Really?
I Hope you got it!
Really thanks! :)
01 - Audio Right Out
02 - Audio Left Out
03 - S-Video Input 2, S-Video Input 4, S-Video Output 2, S-Video Output 4, GND
04 - VGA 5
05 - VGA 13
06 - VGA 14
07 - S-Video Output 3
08 - S-Video Output 1
09 - Video Out - komposite
10 - <n/a>
11 - <n/a>
12 - <n/a>
13 - S-Video Input 3
14 - S-Video Input 2, S-Video Input 4, S-Video Output 2, S-Video Output 4, GND
15 - S-Video Input 1
16 - <n/a>
17 - <n/a>
18 - S-Video Input 2, S-Video Input 4, S-Video Output 2, S-Video Output 4, GND
19 - <n/a>
20 - <n/a>
21 - Audio Left In - komposite
22 - Audio Right Out - komposite
23 - S-Video Input 2, S-Video Input 4, S-Video Output 2, S-Video Output 4, GND
24 - Video In - komposite
25 - VGA 10
26 - VGA 12
27 - VGA 15
28 - VGA 9
29 - <n/a>
30 - <n/a>
C1 - VGA1
C2 - VGA2
C3 - <n/a>
C4 - VGA3
C5 - VGA 6, VGA 7, VGA 8
it should be correct.
edit: found the file: http://mitglied.lycos.de/gtxe/v3_3500tv_pinouts.doc
saint_germain
You don´t know how much happy I was!
Sincerelly, thanks!
saint_germain
i will post the solution tips for some one who have the same `problem and wants to make his own vga cable
I came from studying, and put my hands on.
I use the followings parts:
an dvi-vga converter
a vga header from an old Socket 7 board
estaño?
soldering iron
vinil tape
cutter
angular amolator
pinza?
I cuted all plastics from the dvi-vga conv and put the dvi conn naked
. quited all pins from dvi conn and putted in the right order.
whit the amolator, cut of the opposite side to the ``+´´ pin form (only the metal wall)
next, dissasembled the vga header and peeled the cables marked in the table
solder all cables to corresponding pins of the dvi header
isolated with vinil tape and connected to the card.
this solution is temporal and onli is for get video from the card, because i dont´have enough pins to connect the other things.
it take me about of 3 hours, because peel the dvi conn with a cutter is hard and im afraid to damage the conn
Please, forgive my bad english,i only can read good, but write is hard for me.
now is the 2 of the morning and i get asleep on the pc.
if the moderator wants a detailed guide, please sen me a message and i will put a good guide, not a reference like this
bye.
Tualatin
Good stuff, glad it worked out for you.
Please show us the pictures of your mod :D
